Re: 5.0 Alpha Gen II overheating at low speed
This is what it should look like ...notice after system fills with water ....water NOT STEAM ...flows out of relief ports on either side ..and the prop exhaust.
http://www.youtube.com/watch?v=holZI181KzM
OK ...at this point its best not to assume anything ...... you may have good gpm flow from your raw water pump but you may not have ideal..... re the squeeze hose test ... this is only to see if you have a pressure build up in the hoses going to the manifolds which indicates a blockage in the manifolds or risers or debris in the Y exhaust tube... see how much you can squeeze the hoses when the engine is turned off .....even if you have to use plyers ...you need only squeeze the hose by 1/4 of an inch cold ......you will able to tell right away if you have a blockage as at 2000 RPM as the hoses will be very hard. If they are hard on muffs go to (INSP)
WARNING ..... do not let your risers get over 200 on your IR thermo or you can start to burn the rubber on the riser to Y tube!
WARNING ...do not attempt to check risers by hooking up a garden hose to the riser hose as you risk getting water in the engine !!!
So if the hoses are hard you have good pressure from the raw water pump BUT maybe not up to spec .....we'll get to that in a moment .
(INSP) So if you find the hoses are hard you got a blockage problem...... first pull the hoses and check for debris at the hose to manifold fitting ..... then pull the risers and check the water jackets for blockage ....check that the gaskets are properly installed and that you have the right gaskets ...... go fishing down the Y tube with a coat hanger wire and mirror and light and make sure there is no debris in the Y tube like old broken shutter ...Get hold of a new riser and compare to yours ...... if you have corrosion build up on the water jacket walls this is enough to block proper coolant flow ..... if the risers have been running hot due to poor impellor even in fresh water they will rapidly corrode .... any pro merc mechanic can tell you or maybe they are so bad its evident that they should be replaced. If there is any scale in the exahust tube itself they should be replaced! the inside of the riser should look like the inside of the tail pipe on your car/truck ...carbon , thats all !!
without a flow bench its very hard to test manifolds ...if the risers are OK then the problem IS the manifolds ....... if the risers are dodgy ..replace them.
OK ...about manifolds ....... basically they have an average life expetancy
of 6 to 8 years .....just had a friend ruin his 3.0 engine with 7 year old manifold ...... up to you
lets say for the sake of "how to test your GPM flow" that you fix above problem and elliminate the blockage .....
You got a bin to stick the leg in ....excellent ...... so mark down from the top of the bin 10 gallons of water ..... remove any hose refilling the bin and start the engine at zero seconds ........ watch the level of the water in the bin ...after 30 seconds your raw water pump should have picked up around 9 gallons. If not you have a pump issue as I gather you have backwashed any debris out of the cooler line. KEEP IN MIND this test is useless until you have free flowing manifolds/risers.
Based on the fact you have checked the impellor odds are risers/manifolds are the issue .....GOOD LUCK
