I have the TBI motor, and when doing a recent fuel pressure check to troubleshoot my hesitation problem, I noticed the fuel pressure drops as soon as the pumps stop. Question is, should it be happening on this system? I know it has a return line, but I "assumed" it should maintain a certain level of fuel pressure in the line after the motor is shut down. It drops to 0 in a matter of seconds. Is this a sign of a bad fuel pressure regulator?
My fuel pressure from low side is around 14psi, and from the high side 34psi, and does not fluctuate but 1 or 2 psi under load and sudden throttle movements or WOT.
Thanks
Thanks
