5.0 GXi-G fuel pressure regulator
1994almeida
Hello.
On the VP 5.0 GXi-G engine, when the ignition is switched on, without starting the engine, the fuel pressure regulator gives these values.
Are these values normal or a little high?
I need to do something or not.
Thanks
View attachment Fuel Pressure 1.mp4
For the most part, could be.
Spec list 50-60 psi and don't know how accurate your gauge is. It it is accurate then its a tad high, but won't be an issue if it lowers to 60 once started
