5.0 GXi Volvo Penta engine vibrates
1994almeida
When I start the 2007 5.0 GXi Volvo Penta engine it vibrates and makes the steering actuator oscillate.
However, if the engine is restarted immediately afterwards, it starts normally without any vibration.
If I start the engine after 5 or 10 minutes it starts normally.
However if I start the engine after an hour or 2 the vibration problem returns.
After the engine starts the vibration stops and the engine works normally.
View attachment Motor OFF.mp4
What could it be? Fuel system? Water entering the cylinders?
Thanks
QBhoy
Hi. It’s looking like it’s miss firing or one or two cylinders aren’t firing for a second there. I’d be looking at the distributor to start with perhaps
QBhoy
If not the diz…look for a couple of loosely fitting HT leads perhaps.
1994almeida
OK, but If I start again the engine after 5 or 10 minutes it starts normally.
Cap and rotor are Ok
