Re: 5.0 L EFI Mercruiser motor and/or Alpha Drive problems
My experience has been positive so far. The Mercruiser 5.0 is the tried and true Chevy 305, so you can feel comfortable about having about 30 years of engineering refinements behind it. Fuel injection is awesome, and has always been (for me) so much more reliable than a carb. My 5.0 EFI has a fuel cooler, which may help reduce vapor lock (so the manual says....).<br /><br />The Alpha 1 outdrive seems a little less than bullet proof, like the engine. A little tap against a rock last summer snapped the skeg right off.... but I guess that's better than the entire housing shattering!<br /><br />From what I see others have posted, it looks like the biggest concerns are around past care and maintenance, which I would say goes for any and all engines. You don't say how old the set up is, but I think the advice on having a good marine mechanic check it out if used is the best to listen to!<br /><br />Good luck!
