gjohnson1969
- Joined
- Aug 6, 2007
- 2
Hey guys,
I'm new to the forum as I just purchased my first boat. It's a 1999 Glastron GS205 with a 5.0 liter Mercruiser. The motor runs great, only has 100 hours on it, however, It's giving me a little problem with starting. It just seems to drag like the battery is low. I've put two brand new batteries in it and it still did the same thing. I noticed the battery cables were pretty rusty so I replaced those and cleaned up all the remaining terminals to the starter and the grounds. It's starting a little better but still doesn't start as quickly as I thing it should. It tends to hesitate for a moment when you turn the ignition switch all the way over and then starts turning over somewhat slowly but then speeds up and cranks. Could the starter be bad? Or does the starter just need to be removed and the brushes cleaned? Any information to help fix this would be greatly appreciated.
Gjohnson
Gjohnson
