onsiteservice
- Joined
- Jun 21, 2012
- 29
Didn't have a lot of time to work on this Saturday going back today to try and diagnose. It's a 2003 Ebbtide with the 5.0 merc with the electric in-line fuel pump. The engine cranks fine but has no power to the fuel pump and the distributor is not firing. Ran fine the day before, checked the drivers safety switch it's OK. What other safety switches would kill fuel and ignition but still allow the engine to turn over? If none, then does anyone know if the power supply to the pump and the distributor are on the same circuit? Both sides of the coil had power, the white w/red stripe wire had 12 volts with ignition key going into the distributor. Any help would be appreciated! Thanks, and sorry didn't have time to get the serial # Saturday....
