wewefirex2x
- Joined
- Feb 19, 2007
- 267
I took my boat to the shop Monday. 1989 Monterey 5.0 GM 2 barrel carb Alpha One. The boat would not start for anything and when it finally did it had a miss. The mechanic said compression was 165 on all cylinders. I took him NEW carb,thermo. housing, water pump and fuel lines. Once all that was on the mechanic started the boat and found a miss. Once the valve covers were removed he found water in the heads. Pulled motor from boat to find out where the water was coming from and found a crack in the valve body. The oil at this point was like coffee.
How can a motor have good compression and still have a crack in the valve body?
Is it worth the money to repower a 20 year old boat with a Jasper?
Personally I would like to repower only because NO One will buy a land yacht.
The final price with the work that has been done and the repower will be around 5000 dollars! OUCH
