5.0 Mercruiser sudden rough idle and bad miss
Wave thumper
Any ideas on this?
5.0 mercruiser, qjet, electronic ignition
boat is running perfectly until it develops a really bad miss while underway, and also at idle. So bad the motor sounds like it is running on 4 cylinders, and stalls at idle
I changed
the coil with new one
new ignition module
leads are all ok
plugs look ok but some were fouled with fuel and some sort of blackened when I cleaned them with the tissue
sometimes I get a black puff out the carb when I try to start it
oil looks ok - no water mixed with it
Then I replaced the dizzy with a good spare
All these checks/ replacements have made no improvement!
Any ideas? What do I do next?
I wonder if I have blown in the inlet manifold gasket?
Re: 5.0 Mercruiser sudden rough idle and bad miss
I'm thinking you should do a compression test, may have a head gasket issue. You could also try pulling plug wires off one at a time to see if any of them have any effect?
Any ideas on this?
I changed
new ignition module
leads are all ok
Ayuh,.... Sounds like a Carb problem to me,....
harleyman1975
Ensign
Do a compression test to rule out a hard part failure (valves, piston, head gasket) and if that is ok then I am with bondo possible chunk of something in the carb.
Wave thumper
UPDATE
Compression was OK
Removed the inlet manifold to find a small oil leak to 2 of the inlet ports.
Also found 4 inlet ports in the head totally flooded with petrol, those inlet valves were sitting in a pool of fuel
Then I checked the primary metering rod piston in the carb, it was stuck open.
So I believe the primary rods were letting too much fuel into the engine until she finally flooded and caused us to limp home
What do you guys think?
UPDATE
Compression was OK
Ayuh,.... Sounds like the carb needs a full, 'n complete Rebuild,...
