1993 5.0 mercruiser 2 barrel,,,,, surge n stop....fuel or spark?
If I give the symptoms perhaps someone has an idea of where to look first. This 5.0 just had the carb supposedly rebuilt by shop...has all new coil/plugs,cap,rotor,etc, and wires. All guages and other key indicators are running where they should....
If fires up nicely and runs smoothly. Then after about 5 miles all of a sudden it will start to stumble and if you give it more throttle it tends to bog....back off and stop and it'll tend to settle at idle and you can run it a while at idle and sometime it will simply surge up a thousand rpms and fall back,,,,usually after 10 minutes of not being able to add throttle without bogging,,,it will die. Then won't restart, but, if you wait a little then it will start and run a few seconds and die. Or if you throttle all the way forward, it will want to start, but die.
I checked the water fuel separator and dumped it out....some fine stuff in bottom of gas,,,did not seem to have water in it.....
Then after a half day it started up again and we ran about 2 miles this time and it started to stumble and the only solution is back off the throttle to keep it running,,,,another 10 minutes at idle in gear moving and eventually die again,,,,same scenario.
Is there a fine screen in the 2 barrel carb that can plug,,,or does it sound like something is shorting out and not getting spark? Does it sound like a water in fuel thing? I'm frustrated to find the culprit...
Any ideas and key checks before I take to the shop with guys that don't seem all that competent to me,,,unfortunately not a lot of choices in my area,,,,no mercruiser people believe it or not.
Thanks
Thanks
