5.0gi TBI to Carb
Galvez83
Guys, after much headache and suffering with my TBI (a lot of money invested) still having issues. I have decided to go the route of Carb. What is needed to do a proper conversion using my current wiring harness. My current set up is a 2000 Volvo Penta 5.0GI PEFS TBI with serial # 4012007012, I know i will need
Carb
Spreadbore to squarebore adapter
Low psi fuel pump
Oil switch
Relay
Coil
Dizzi (read that stock Delco can stay)
The issue arrises when it comes to what wires go where to. Any thoughts?
QBhoy
Hi there. I can’t help you too much on this..but you mind if I ask what issues you had from the Tbi ? Never had one, but thought they were simple enough and reliable enough.
If this was a Merc it would have 2 harnesses, motor and a EFI. There would be a connector which joins the 2 harnesses together. Does your motor have a similar connector?
jimmbo
If your engine has a 4bbl Intake, Volvo likely used one that accept Spreadbore Carbs as well as Squarebore
My fave carb for Marine engines up to and including 454s
However a 5 liter spinning 5200 rpm will find the 500cfm carbs perfectly sized
Lou C
I’m not sure about the wiring set up on the Volvo but I think if you can study the schematic you might be able to figure it out.
If someone has one to post up then we can make suggestions
You don't need an adapter
Just need to buy the right manifold.
Volvo runs a 500cfm Holley 2-barrel or a 650cfm Holley 4150 4-barrel
The manifold is very similar to the Edelbrock 2516
If your existing manifold has an adapter, just toss that and bolt on the carb.
Use a Holley fuel pressure regulator and you keep your existing fuel pump
QBhoy
Scott…sorry to hi jack a little..but have you known a holly to be fitted to a 5.7 repower engine, without an electric fuel pump before ? And tell me more about the holly fuel pressure regulator. What if there isn’t one of them fitted ? This is relating to a set of engines in a friends boat. Posted she’s ago about it. Thanks.
Don't agree, the Gi has a low and high pump combined in one unit. Not going to regulate 55 psi down to 5 psi and keep it that way
jimmbo
That Edelbrock looks very close, to the Intake that is on my VP5.7. It is a very well designed Intake. The runners look similar the runners on the 1970 LT1 Intake and can flow quite well
jimmbo
GDI
The link to the 2bbls used was FUBAR. so
Any of the above are pretty much the Perfect size for 5 liter spinning 5200
Galvez83
The engine has only one wiring harness that connects at the back of the boat. Regarding the carb i can work around that but my main concern would be the wiring to get everything going including gauges. I have read some people say its easy while others say they had to cut wires. This is my current set up.
  • Schaltplan GSi 57 (2).pdf
Your not helping
A wiring diagram from the manual doesn't necessarily show if there is or is not a connector. For the sake of discussion lets say there is not a connector. Follow the wires from the 10 pin which go to the ECM and the ones that do not.
The ones that do not, leave be, the ones that do identify and we can figure out where they need to go
Galvez83
Your not helping
Tomorrow i will gut the harness open and take it from there.
both cast at Barr castings.
the OP has a TBI motor. either an 11 psi spring, a 15 psi spring or a 30 psi spring in the existing regulator assembly on the TBI assembly.
Yes 30 psi not 55, The motor has a regulator in the TB, but the motor uses 2 fuel pumps mounted together and regulated to 29 psi +/- 2. Using a Holley Reg designed to regulate 10 psi or less down to 5, and have 30 coming in is not a good idea in my opinion
Lou C
Michigan Motorz sells the set up you’d need for a carb conversion (pump, bracket & oil pressure switch).
I’d want to see how the original ignition system is connected to the ECM and then figure out how to wire around that…might be able to eliminate the ECM entirely.
Galvez83
Update,
After a whole bunch of back and forth due to a bent crankshaft snout, crappy mechanics and machine shop, the engine is back. During the time that the engine was being repaired i changed to a 30lbs spring and changed the anti-siphon valve... still no improvement. The carb, equiptment are all on hold till i get a good mechanic to evaluate the current state of affairs of the boat.
