83Evinrude
- Joined
- Sep 3, 2008
- 290
Upon arrival it appeared fine so I installed it and tested on muffs, and after the engine filled up water came out around the transom as expected.
Last week at the lake I ran the boat three times, mostly at low planing speeds under 3000rpm and the temp ran 160-170 each time.
On the fourth time out as we headed back to the ramp I opened it up a bit, probably reaching about 4000rpm and after a few minutes the hot horn sounded and the temp was around 200.
I stopped the engine, trimmed up the out-drive and checked for debris on the intake but found none and a engine bay check found no obvious problems either. You could touch the manifolds but they were clearly hot, and you could feel water bubbling inside.
Waited a few minutes, then restarted to see if lower speeds would provide enough water flow to cool the engine but this didn't happen.
A friend towed us back,and by the time I backed the trailer down the ramp running it a couple of minutes to load on the trailer did not produce an overheat.
At home, I didn't hook it up to muffs but took the pump apart to see what shape the impeller was in.
I've linked to pictures of the pump, impeller, thermostat housing and intake manifold where it bolts to.
The pump has a groove in the back of it but I'm not sure if this is a problem or not.
The impeller appears fine to me, and after taking it out the vanes returned to just about straight after a few minutes.
I took the thermostat housing off to see if it had stuck closed but I can't see how to get it out of the housing, and every automotive application I've seen would have had the thermostat in a groove in the intake manifold and held down by the housing. Water will run through any of the housings hose connections to the others so I'm not sure how it functions where its located.
Sticker on the motor has these markings: 5.0GL-D, 3869216 and 4012100510
Thanks in advance for all advice.
http://s85.photobucket.com/user/ston...Pump.jpg.html]
http://s85.photobucket.com/user/stonypass/media/VolvoPump/Impeller_1.jpg.html]
http://s85.photobucket.com/user/stonypass/media/VolvoPump/Impeller_2.jpg.html]
http://s85.photobucket.com/user/stonypass/media/VolvoPump/Housing.jpg.html]
http://s85.photobucket.com/user/stonypass/media/VolvoPump/Manifold.jpg.html]
