5.0L GM Surging at cruise
ufm82
Boat was running fine Saturday until I was headed back to the ramp- it started surging BAD. Up and down, up and down. Lost 700 RPM on top end but it idled fine. Take off was still good but anywhere 2000-4000 RPM, it would surge really bad. Even at WOT, it didn't have the power it did. Any ideas?<br /><br />1990 5.0L Mercruiser- GM power, carbed.<br /><br />Fuel/Water separator was clear, half tank of fresh fuel, running smoothly as in no missing, but surging badly. <br /><br />UFM82
stormin4
Re: 5.0L GM Surging at cruise
Had a similar problem with my 4.3 OMC. Check your alternator to make sure it is working. Also, check to make sure none of your spark plug wires are loose.
gpane
hi, thanks for replies<br />Things done: alternator belt was little loose, tightened to specs; changed thermostat; put fuel cleaner in tank; took of top of carb(edelbrock 1409 installed new last season) and adjusted float drop was 1/2 in to low and srayed with carb cleaner.<br />took the boat out next day ( fuel cleaner recommened letting sit for 24hrs- starbrite product)it ran great for the day then today problems started again: went out and after 10 minutes started to bog down and surge...got towed in and in dock i drained water seperator and gas had tiny dirt specs and some gell like substance forming on bottom( small little globs), i also removed paper fuel filter from canister and tore it open but it was clean...any ideas???? also after drained fuel was sitting in container for 15-20 min it became very cloudy wasn't clear anymore; in fact couldn't see bottom of container anymore...is that normal?
gpane
sorry wrong post read omc bogging and surging
That's Dirt,+ Water..........<br />That's Also the Cause of Your Problems .......<br />
No......<br />I Suspect it's got Something to do with the Fuel Cleaner you added.......
