5.0L Mercruiser Engine Question
mounty
My engine serial number is 0w360991 which i believe is the 305 CU IN GM V8 with a Bravo III outdrive. In the manual i see reference to a single point drain, 3 point drain and online I see a 7 point drain referenced. I'm not at the boat and wondered if there was some way to find out what my engine has without looking at it. I want to change the thermostat but not sure which configuration I have.
Thanks in advance
mounty
it is a closed cooling system. what's the difference between a one point and three point cooling system?
QBhoy
Also to be suggested that it’s a good idea not to trust the function of such a system entirely. Good idea to verify all is doing what it should...when it comes time to winterise and drain.
