I have a 200LS Crownline w/ 5.0L MPI 1.62 alpha 1 w/ MM Vengeance 21P SS prop. The motor now has 27 hours and should be broke in. Current performance with 3 on board and gas is 51-52 mph (speedo) and 4600rpm. Which is reached after 6-8 seconds of WOT Operating range is 4600-5000 rpm. With the current load (normal for us) I think I should be closer to the 5000 rpm range. I am considering a 4 blade SS prop like the turbo 2+2 or the MM Vensura. What effect will the fourth blade have on the rpm in the same pitch as the three? Any experience with these props? Suggestions for others?
Thanks
Todd
Thanks
Todd
