5 1/2 hp CD-18 Johnson year?
Scaaty
SeaHorse 5 1/2 HP, CD-18 Ser# 2148389. Asked before, and can't find the paper I wrote it on! Thanks in advance.
JB
Re: 5 1/2 hp CD-18 Johnson year?
That's a 1961, Robby.<br /><br />24:1 fuel mix. :)
Scaaty
Great little motor! Thanks JB. (yes, I wrote it down and its with the outboard folders!)
Paul Moir
Have a look here for some good info on the 5.5hp:<br />Click here.<br /> <br />An easy way to find your old posts (past 50) is to click on the "Search" button, select the group you want to search and put your member name or number (42432) into the "Member Number or Public Display Name" field. Leave the "Search Words" field blank.<br />You'll get all the posts you ever made to that forum.
Scaaty
Thanks Paul...great site. I sometimes (ha!) forget the old Google thinghy, and the many sites pertaining to all things outboard. This motor is missing the front "carb" cover (don't know what else to call it-where the mixture screws come through, and need some seals in the lower. Picking up water. Also it will fire right up if I squirt a little gas in the carb, but choking alone it will just not start. I'll work on it over the winter. Thanks again
