5 1/2 HP Fisherman fule line
Lee Blatter
I have a 1958 Evinrude 5 1/2 HP Fisherman for which I need a fuel line (with connectors) and fuel tank.
64osby
Re: 5 1/2 HP Fisherman fule line
Is this a two line pressure tank set up or a single line?
Does the motor have a fuel pump?
If it is a pressure tank set up you have to search for a used tank, and probably rebuild it.
You could also convert it to a fuel pump set up and get a standard tank and line for less than a pressure tank set up.
Welcome to iboats.
gsxatc
Lee-Look on Ebay for a two line pressure tank. Search Johnson fuel tank. You might also find connectors there, and expect to pay around $100 or more for the tank. They are a precious commodity. Another source for that year motor would be the Antique Outboard Motor club at www.aomci.org. The site has a classified section and other resources which could get you started.
