5.5 evinrude impeller
stingertrey
Do I really have to pull the powerhead on this engine to change the impeller.. I read somewhere that you had to even though its between the upper and lower unit??????
lindy46
Re: 5.5 evinrude impeller
Yes - shift rod must be disconnected under the powerhead to drop the lower unit.
stingertrey
Ok thanks mine isn't pumping water so I've orderedd one
jeff_smith_0423
it's a piece of cake. it's either seven or eight bolts. (been a bit). Disconnect the fuel lines, throttle linkage, pull the bolts, crack the seal, disconnect the shift rod. Make sure you replace the powerhead base gasket and clean out all of the gunk while you're in there.
