Cabinupnorth
- Joined
- Jan 24, 2003
- 8
Just bought a '62 5.5 Evinrude at an auction, replaced deteriorated coils (aligned heels with machined areas on mag plate, motor now runs excellent, but seems like magnets are real strong on flywheel, when you pull over, mag plate will pull throttle to off, and when you idle down real slow mag plate moves back and forth if you hold the throttle, if you don't hold throttle it will rotate throttle to off. I have a 73 6 hp that I did the same thing to last yr. and it is as smooth as could be. Can' find any kind of friction adjustment for throttle. Any thoughts??
