5.5 seahorse
kenra
I need to know the year of my o.b. I cant find<br />the model# or serial#. It's a green 5.5 seahorse
kenra
Re: 5.5 seahorse
Thanks Bear<br />I did find it it's cd-10 and the serial# is 1088967 These were on a plate located on the clamp that secures the o.b. to the boat.Although I still cant find the year any ideas? By the way it is a Johnson and it's green with white lettering and outlined in red
kenra
Re: 5.5 seahorse
Thanks again Bear,<br />I put Castrol hypoy c gear oil sae 80w/90 it says on the case where I added it "use hypoid oil"<br />Is the oil I used okay? and as far as pre-mixing my fuel is regular 2 stroke oil okay? I also had a problem when I ran the engine it would run as long as the choke was on but when I turned the choke off it would die any suggestions?
alcan
Re: 5.5 seahorse
Hi Kenra<br /> The gear oil choice will be fine. Two stroke TCW-3 mixed @ 25:1 will do for the motor. As far as the choke thing goes there are a lot of things that could cause this. I suggest a compression test first. Then look into the fuel system. These model use a presure full system. They have no fuel pump. So any leaks in the tank,hoses or connector would be a problem. You probably also need to disassemble the carb and clean it.
OBJ
Re: 5.5 seahorse
Hi Kenra...<br /><br />Don't know much about the Castrol hypoy. I use OMC hi-vis or ultra hi-vis in gear cases and have not had a complaints. I'm sure any gear case oil for outboards will be OK. Use a two stroke oil specially made for outboards. Lots of good brands on the market. Merc, Bombardier, Yamaha, Lubri-plate, any of these will work. Look for the TC-W3 rating on the container. Sounds like the old Johnny may be in need of a carb rebuild. When it runs with the choke closed and dies when the choke opens, this generally indicates pluggage in the lift tube from dirt or usually varnish or gum. If you have nerver had one apart, I would strongly suggest a service manual to guide you. Carb kits are still available for these older engines as well as ignition parts and water pump impellers.<br /><br />Jim
kenra
Re: 5.5 seahorse
Thanks for the help alcan<br />I'll try cleaning the carb and see how that works
kenra
Re: 5.5 seahorse
Thanks Jim I'll get the outboard pre-mix<br />and I'll order a manuel for rebuilding the carb
