Going to rebuild a 5.7 as a winter project. Several weeks ago I lost the motor from a dropped exhaust seat due to a cracked exhaust manifold.
The motor is a 1996 5.7 crate that was using the 1986+ style 64cc non-vortec heads and mechanical flat tappet cam. Last year it was upgraded to a 4 bbl but it was cobbled due to an early style intake with the wrong center bolt angle being used.
I don't want much more power due to outdrive limitations, just looking for around 300h.p. Should I stick with the 86+ non vortec heads, Go vortec ( and get correct intake for quadrajet), or go for some aftermarket heads?
Looking at doing a .030 overbore, flat top, four valve relief pistons, and a comp cams X270 marine cam. Or do you think this is too much?
