5.7 EFI 2001 - clicking and
alternate550
ANY HELP WITH SUGGESTIONS ARE APPRECIATED
I have a 5.7 EFI Mercruiser and hear intermittent but ongoing clicking or ticking at 2600 RPM and above. Otherwise, it runs well. The clicking or ticking comes from the top of the motor's center between the carburetor and the drive belt. I have a video but cant seem to post it to the site.
The fuel filter water separator was recently changed. The spark plugs and wires were changed three years ago and have 20 hours of operation.
Welcome
Put vid on a place like youtube and link here
Have a motor serial number?
Listened to it 3 times and my old ears cannot hear anything I would be worried. I'm sure it's there but I just can not hear it
Scott06
Might be the belt but would take belt off and see if tensioner pulley and accessories trim smoothly
alternate550
it was the tensioner/idler pulley which was worn and had bits of rubber embedded in the grooves from the last belt. Thanks a ton for the direction!
OwenAdams
NEW VIDEO. Clicking sound - Mercruiser 5.7
Belts, detonation, ??
It sounds like the ticking could be from the valve train, loose components, or an exhaust leak. Check the valve lifters, ensure all parts are secure, and inspect the drive belt and exhaust manifold. If you’re still unsure, a marine mechanic might be able to diagnose the issue more precisely. My friend suggested academized.com/research-paper-help when I was struggling with my research paper, and I’m so glad I used it. The paper was well-written and thoroughly researched, and it met all my academic requirements. If you’re like me and need help with research papers, I recommend trying this service. It made everything so much easier, and I was able to submit a high-quality paper on time. I’ll definitely be using this service again in the future.
Can I ask something regarding this issue here? I am sorry for jumping in someone else post.
