5.7 fuel pump
Groupergulper
im currently rebuilding my 1986 5.7 mercruiser. just before the cylinder wall rusted thru, (another Story, New Block) the fuel pump went out. in a bind i put an automotive pump on. The original marine pump Part#861678a1 i still have, is it rebuildable? if so where do i get the new parts. also with the new rebuild i switched to a edlebrock marine carb. If i am correct, i do not need the extra small line goin go the carb from the fuel pump? so do i get a pump from an older 5.7 or rebuild the original pump and just block that line off?
Re: 5.7 fuel pump
Ayuh,... I haven't seen a fuelpump Kit in many a years....
Buy a New 1....
The clear line is to alert you the diagphram is ruptured...
If you run a mechanical fuelpump, ya gotta plumb it to the carb....
Groupergulper
Re: 5.7 fuel pump
thanks for the insight, i didnt know what the small line was for. it wasnt clear on mine. someone must have replaced it, with black line.
Groupergulper
Re: 5.7 fuel pump
so i bought a new one, does it take the thin paper gasket, where it mounts to the plate that mounts to the block. Maybe im thinking about automotive, but some of them have a thick (3/16) gasket. whick one do i use?
Groupergulper
Re: 5.7 fuel pump
i found it, the other pump had a longer arm, the merc pump only gets the paper gasket.
