So yesterday I was out boat ran normal throwout the day. on the way in the seas were less than fun so i was traveling about 19-2000 rpm... as i increased the throttle the motor seemed to pop/backfire and die. it started and i was able to advance to 19-2000 rpm again. as i attempted to increase the throttle again it hoped/backfired and died. it would lot start after this.. upon cranking the injectors would not spray any fuel.
touching both injectors with a 9volt they both click.
I cleaned the grounds on the block.
I removed the hp fuel pump and it seems clear of any debris.
I have attempted to check the fuel pressure my gauge reads 10 psi, im not sure if this is correct. the only way i was able to hook up my fuel pressure gauge was to take out the schroeder valve on the hard hp line and place a piece if fuel line over the schreader valve then slide an adapter to my gauge.
What are some things i can check as to why they will not spray fuel?
thanks
thanks
