Hi,
I have a VP 5.7 GSi (model WT - '99) with a duoprop driveunit.
The boat sits 6-8 months every year in salt water. I have seen that VP offers a "Fresh water flushing kit" on their newer engines - unfortunately it is not installed on mine. It seems pretty simple - the water inlet hose from the driveunit to the raw water pump has been cut and a 'T' with a hose has been installed. My question is if the engine must be running while performing the flush or not....
I see some issues...
If flushed while running the engine I guess the raw water pump will pick up a mix of salt water from the driveunit and freshwater from the flushing kit - No valve to close the salt water intake hose seems included in the kit ??
If however supposed to be flushed while NOT running the engine - I guess the fresh water hose must perform a very high pressure AND still will it be sufficient to pass impreller and circulation pump ?? and another issue - If the engine is cold the termostat is closed so the fresh water will never enter the block........
Sorry I must be missing something ;-)
Great forum - Your help is appreciated.
