5.7 harmonic balancer
Galvez83
Folks can someone advise me regarding an engine swap i did from 5.0gi PEFS to a 5.7. Everything is the same exept the engine. The issue i am having is that the new 5.7 has a lot of vibration. To the point of tossing the serpentine belt off the crank pulley. The balancer is new 8 inch because the old one was doing the same thing after transfer. I thought it was the balancer but clearly i was wrong. The balancer for the old 5.0gi pefs is 3856924. The balancer is 8 inch in diameter. The question is is the balancer for the 5.0 the same as the 5.7? The current balance is installed correctly and bottomed out in crackshaft.
Ayuh,.... Both the flywheels, 'n harmonic balancers are interchangeable 'tween the GM 5.0l, 'n 5.7l motors,....
You pull one spark plug at a time and observe idle RPM. Every cylinder should drop 40--50 RPM. When you get a cylinder that doesn't drop, you have a dead cylinders
If pulling a plug wire results in a higher idle, you have cross-firing happening
