5.7 has oil leak on top of engine
DINGOBOY
I have a Merc 5.7 carbureted engine. Everything is fine except there is always oil in my bilge. I think it's leaking up high on the port side head around the pcv tubing etc..... some oil laying on intake manifold on same side. PCV tubing looks oily too.......
Bt Doctur
Re: 5.7 has oil leak on top of engine
GM V8:
valve covers
dist shaft
oil pressure sender
high oil level
high blow-by pressure
Ayuh,... Like a Water Leak, the Only way to find an oil Leak is,.. LOOK...
It flows downhill, so the Leak is at the top of the stain...
