walleye seeker
- Joined
- Mar 1, 2010
- 81
2003 mercury mpi 555 ecm 350 mag.
Here is the problem. I take boat out get it ready for season first day runs beautiful.
Bring boat home decide to change my ex flappers {rattling}they are the old style 1 pc oval. y pipe is attached to an mr drive housing.
Take boat back out another day wont hardly run
My engine is hooked up to alpha 1 gen1 drive that is connected to an even older bracket at transom i beleive mr its a 1986 crestliner sabre
Did i install them backwards when you look down the y pipe the are open. if water were to rush in from back they would close i beleive this to be correct. If i flipped them over the ex would push them closed.
Also another post i pointed out i found 1 of the screws holding down the distributor cap is broken not the screw itself but the hole it screws into on the distributor my quick fix so it wasnt moving aroung was to zip tie the cap to the distributor which is working fine.
I have the smartcraft gauges and i am not getting any faults but it wont let it rev past 3500rpm . so it sounds like it is restricting my rpm or limp mode. no other messages come up.
I pulled plugs they are nice and tan and dry. Boat fires right up and idles nicely
What am i missing
What am i missing
