Rebuilding a 96 5.7, installed a LT-4 HOT cam by GM and will be installing vortex heads.
The current old pan is a GM 10242245 5 qt pan. Is it recommended to go to a 6 qt pan like the GM 10055765 or stay where its at?
Plan on standard volume/standard pressure pump. Speaking of that what is recommended a .625 inlet tube or the .750?
Reason I am wondering is the bearings looked like they were oil starved, this was with a standard volume/pressure. Was thinking that at high RPMs the pump was sucking air.
Suggestions?
Suggestions?
