Nick_1987 5.7 OMC
- Joined
- Apr 26, 2020
- 125
Hey all back again, sadly…. So I have a 5.7 omc from 1987-89. Just did a carb clean on the motor and everything is fine in the mechanical side of things but I think I may have a electrical issue. While running a few days ago, the motor was stubbling out of the blue and then back to normal after 10 sec of stumbling. I Would try and rev out of it but it would just die completely. Decided to see motor running with the hatch up. While the motor had is “seizure” I ask my father to wiggle the harness around along with the rest of the electrics back there and it seemed to stop something from interrupting the motor. After he would set down the harness the motor would stumble again. Once he wiggled it around and help it in his hand the motor ran fine. Another thing today while running into port boat was running fine then while de acceleration. The boat stumble again mid way through at around 2000 rpm and then died. After I went to check under the hatch there was a leak on the starboard side of the carb, right by the lever. I will attach a photo for this. About the electronic kicking in and interrupting the motor I have no idea, I’d guess a loss connection somewhere but that’s why I’m here. Now the carb leak maybe I didn’t tighten down the carb enough and after a few hours of running things came lose. Or maybe the vibrations from motor stumbles made a crack somewhere. I’m not sure, that’s why I’m here. Any help is much appreciated!
