5.7 Overheating
Darcher99
Ok. Coming back to the knowledge pool. Put a new long block in. Got it to start and running. Now, it overheats at idle. I believe that there may be a small exhaust leak...would that cause it to run hot? I am fairly new to this. I just need to know if I should be looking for a new thermostat, or just tighten up the exhaust. :)
Ayuh,..... Is the drive on it,..??
You are supplin' water to it, Right,..?? How,..??
flashback
You have a new motor but no mention of peripheral parts. How old are the exhaust?
Yep. Outdrive is on and Im putting water to it via earmuffs.
Ayuh,..... Pull the in-comin' hose off the t-stat housin', 'n run it for a few seconds,....
You should have a massive water flow outa the hose,....
If not, work yer way back to the drives impeller,....
If so, is there water in the block,..??
Is there flow outa the hoses to the manifolds/ risers,..??
Darcher99
Water in the block? What do you mean? It's newly rebuilt engine. I hope there's no water in the block. Ha Ha.
flashback
My hope is that you find water in the block. HAHA
It just has to be in the proper place!
QBhoy
What outdrive is she attached to ? Presumably it has suitable cooling set up ?
Darcher99
Just pulled the intake hose to the thermostat hosing and there is no water. Smh. Which is confusing, because everything was working before I put it back on the boat after the engine swap.
flashback
Flush the intake and replace the impeller before you cook your new engine.
tank1949
at idle and muffs on with water ON from spigot, disconnect hoses, one at a time, from exhaust manifolds. You should get sprayed with water. If not, examine water pump in lower unit and the tube that goes to upper unit. But, if you have plenty of water, your thermostat may be defective. Remove stat and see if temperature goes down. If so, replace stat. You may want to purchase an inexpensive inferred temperature tester from Harbor Freight
Darcher99
ok, I took the inlet hose to the thermostat hosing and it didn't spray me. I don't think Im getting water to the thermostat.
Darcher99
The other thing that is really confusing me too is....I am getting water out of the exhaust on the outdrive. How is this happening.
QBhoy
Is there a power steering cooler
is it coming out the prop and or the transom shield ? Have you got the intake hose on right side of thermostat
Ayuh,..... Pull the drive, 'n rebuild the raw water pump,......
Back-flush the system, by hookin' yer garden hose, to the hose ya pulled off the t-stat housin',....
While the drive is off,....
The entire inside of the drive housin' is Wet,.....
Could be the pipe from the pump is misaligned,.....
Pull the drive, 'n split it to find yer issue,....
