Re: 5.7 runs but won't idle after winter storage
Actually, with a little luck, some very small wire or drill bits and some carb cleaner, it MAY be possible to fix your idle problem without removing the carb.
Check the pic of my spare Holley below. The arrows are pointing to air bleed holes. These are behind the secondary barrels, and these particular air bleeds draw air into the secondary fuel circuit to help atomize fuel. Since my carb's choke plate is shut (and not shown anyway), you can't see the idle bleed holes which are in front and above the primary barrels, but they're pretty much exactly the same. Your Qjet won't look like this, but it should have similar air bleed holes. Since you stated that turning out your idle air screws does nothing, chances are your idle air bleeds are plugged, because that's where the air comes from that you're trying to adjust. You'll need some very thin craft wire, or a straight pin, or a drill bit that's smaller than the hole-- good luck, and because drill bits that small break easily, I prefer wire or pins... first, take the hose on your can of carb cleaner and force it against the bleed holes, then spray. Cover your face because it WILL spray right back at you! Then "ream" the hole gently with the wire or pin. Spray and ream a few times. If you're lucky, your bleeds may just be gummed up with a little varnish and cleaning them out may do the trick. If it works, great! If not, you're only out a few minutes of your time and a buck's worth of carb cleaner...
