I can't get my boat into the shop for 3 weeks so I need help figuring this out. I have a 2000 Trophy 2359 with very limited access to the engine. Here's what happened. Cruising back to the marina out of nowhere the rpms smoothly drops in half, then I smelled smoke checked the gauges and the oil pressure dropped from the normal 80 psi to around 20. Temp stayed normal. Stop the boat and open the engine cover and their was oil all over the engine bay. Checked the oil and it was not milky so limped back to marina. I cleaned up the engine and it started right up no leak at idle. I tried to do a compression test but can't even get to the plugs.
I took the boat back out and the leak came back at higher rpm, oil pressure still low and smoking bad out of the exhaust, temp OK, no water in oil. Any ideas on what might have let loose? Thanks!
