Grant Ingle
- Joined
- Aug 17, 2001
- 49
Here's what happened. Replaced the starter mid-season,then the boat filled up with water over the starter. Two wires had burned off the back of the starter itself and another on the separate solenoid 6" above it. Removed and cleaned the starter, then bench tested it. OK. Repaired the wires and installed the starter. It spins just fine but the bendix will not engage the flywheel at all. Tested for voltage at the terminal on the starter and found only 5-8 volts during cranking. Tested voltage at the solenoid above the starter (yellow wire) and still had the same voltage (@7). Shouldn't this be 12 volts?
