Brentathon
- Joined
- Dec 29, 2009
- 399
I want to check timing.
Was there a revision to the timing advance curve in the Service Manual #15?
That curve shows the advance starting as slow as the 400-600 rpm range (see attached)....
If the "base timing" is 8 deg BTDC, the curve shows I should add 5 degrees to that (i.e. 13 total) if checking at 700 rpm.
