So I got a 5.7 engine from a 1998 Silverado that I’m rebuilding, the truck cam in it is roller and flawless so I’m thinking about using it. My question is how much performance difference would there be between the truck cam and a factory marine cam? I have the specs truck is 415/428 lift 196/191 duration lobe 111 vs mercruiser 430/450 lift 197/207 duration, 109 lobe. It’s going on a 2001 Godfrey 24ft pontoon that had a 3.0l in it, yes I have everything including the drive for the swap. If it’s only a few horses I won’t change it, any thoughts?
