Here is my boat info:
1988 VIP 20 ft w/ recently rebuilt (3 years) 350 (4 bolt main) from rapid-o-marine and OMC cobra drive. Pertronix electronic distributor and flame thrower II epoxy coil (also from pertronix), new ESA compatible with the electronic distributor, high performance plug wires, and new plugs last year.
My problem is that at completely wide open throttle the engine misses about one or two times every second. If I back it off just a hair (literally, move the throttle back less than 1/8") the missing stops. The only other time that I experience this is if I give it to much throttle during acceleration (i.e. if I hit the throttle hard at 3000 rpm or go over 3/4 throttle when coming out of the hole). Like I say, it will run fine at 4500 rpm all day, but as soon as I give it just a little more throttle the missing starts again. The missing under hard acceleration is worst of the two situations just because I don't run at WOT very often. OH, and this condition was the EXACT same prior to the eletronic distributor and new coil (that is same problem with points and original coil). I believe I had the same problem before the plug and wire change as well.
The only part of this engine that has not been rebuilt or replaced that I am suspicious of is the carburetor, which is the stock 4 barrel quadrajet. And I know diddly about carbs so I don?t know if this could be a symptom of carb problems or not.
Any ideas or info would be much appreciated!
Andy
Andy
