Today on the river I was running my boat with a 5.7L Mercruiser at WOT (4600). It got to 4600 and the RPMs stayed there for about 60 seconds then the RPMs began to drop and I could hear a ticking noise from the right side valve cover area. I slowed and stopped. The noise continued. I shut off the boat and let it sit a minute or so and then started it and the noise was gone. Again hit WOT and same thing happened. And shut it down and went away. I cruised the rest of the way at about 4000 RPM and had no problems. Any thoughts on what this may be? The noise is a tapping noise, sounds like a loose rocker or exhaust leak. The engine has otherwise been running well. I do have oil pressure and there is the proper amount of oil in the engine.<br /><br /><br />Thanks<br />Chris
