I have a 2001 5.7L GSi pefs serial# 4012044349 3869059 that overall runs very well and most of the time idles right at 600-650rpm. However, every now and then (mostly when you dont want it to) it will idle at about 1000-1100rpm. I KNOW it is not that throttle or throttle body butterfly is sticking. Sometimes i will start it up and it will chug a little bit at idle then kick up in RPM. I can burp the throttle and it still will only come back down to the 1000 range. I can kill the engine start it back up and it idles down in the 600 range just fine. Sometimes i can be running across the lake and bring it down to idle and it runs up in the 800rpm range and if i put it in neutral it goes to the 1000-1100 range. Then i can kill to motor start it right back up and it will idle where it is suppose to at 600rpm. Rarely i have to kill it and start it a couple times but it will idle down and run like nothing is wrong at all. It can get really annoying when idleing along though a cove or when tightening up the rope on a tube if it does not idle down. Any idea what gives????
