Vinnys
- Joined
- Jul 17, 2011
- 67
I have 2 almost dead batteries that I plan to replace. I wanted to turn over engine so I jumped the batteries with dads car. Once the engine was running I pulled the jumpers. Engine ran for about 20 minutes before I shut it off. I put the jumpers back on since I was planning to run it again. Jumped for about 10 minutes. When I turn the key I got nothing, nada, zilch not even a click or a moan. I was confused so I did the old school thing and jumped the solenoid with a long screw driver and the engine made an attempt to turn over. I took the tool away and went back to the key. The key was now working fine. It took a few attempts to get her started, timing is off, but the key worked and the engine started.
I did this 2 more times with the same results. Every time I shut down the key stops working and after a quick terminal jump the key works..
I have not known solenoids to be intermittent so any and all advice is welcome.
New cables and all connections have been cleaned and coated for anti corrosion as usual.
Vin
Vin
