I have a 1989 omc 5.8 just replaced spark plugs and installed new quadrojet carb . Fuel is geting to carb and bat is brand new . Starter turns and turns but won't even play like it wants to start. 2,of the freeze plugs are out at the bottom of engine under motor mounts. I thek it should still start with those out ? I took the plugs off of distributer and ty had an oily substance in them .should i replace starter coil and distrib. Also could I use the thunderbolt ignition off of a mercruiser.
