I have a 5 hp Evinrude Angler, that runs good for about ten Minutes than overheats and dies. let it cool down and it will do the same thing all over again. any thoughts? thanks
When was the impeller last changed?? How do you know the pump is functioning properly? Does that motor have a t stat? Sounds like you have a leak in the water line or at a grommet, not allowing the cooling water to reach the power head. You will need to find the source of that leak. Exactly where is it ?
