Michael Wild
- Joined
- Oct 2, 2013
- 9
Pulled the power head and checked the impeller which is fine. Put all back together with new gasket - seal and o-ring looked good. Did not pull flywheel but visually checked points and gap. Can't see any obvious problem. Now I have sore wrist from pulling and pulling and pulling on the starter rope. Got a couple of firings and maybe 3 or 4 revolutions on its own. My first question is how should the low and high speed settings be set? Do they affect starting?
Second question is regarding those low and high speed knobs and the degree of travel. Decals show number 1 thru 4 for both. If you turn the splined shaft all the way say to 1 (all the way clockwise) and put the knob on with the pointer at 1 there is no way for the knob to be turned all the way to 4. Am I missing something here? I attached a pic of the low and high speed knobs and the choke.
If we (my 88 yr old dad is helping) don't make some progress (checking for spark, etc) we will pull the flywheel and inspect the magneto.
