Today I was going to replace the lower end oil in my 5 HP Tohatsu just like I do every year... The bottom lower end drain / fill screw came loose with no problems..BUT no matter what i do, I can't get the top (vent/fill level)screw out.. I have tried the largest screw driver (wide blade) that I have and it won't budge..I am worried that further attempts will render the slot in the screw totally useless.. I don't want to use heat as the paint on the entire motor is like new.. Ideas???
