mfgniagara
- Joined
- Aug 17, 2010
- 92
I was given the remains of a blown up 1981 20" shaft 60hp Johnson twin cylinder. The power head is toast, broken rod and busted up block, crank, and head.
I have the chance to buy a 1990 parts motor that runs great but it's a short shaft and needs the tilt ram assembly replaced which is why the motor was deemed parts. ($1500 to fix tilt ram). The motor has very low hours, has 151psi on both cylinders and other than the torch cut tilt assist ram, the rest of the motor could pass for new. Is there any parts on the 1990 that will work on the 1981 60hp mid and lower? I can see that the engine bracket is different, but the rest looks pretty much the same. Will the 1990 power head fit the 1981 mid and lower? Is there any solution to fix the 1990 without spending so much to fix the tilt?
Other than being a 15' shaft and the tilt ram problem, the '90 50hp is perfect.
The tilt ram was removed with a torch or saw, they cut the top ram off and left the round end and shaft, and they removed the rest of the unit. It's a shame because I'd venture to guess that the motor probably never saw any use.
