I hope you can help or give me some direction. I can get my motor running, and when it starts it runs great, idles fine and revs fine....at home in a bucket. Problem is it has only started roughly 1 in 30 tries this season. Twice when I've launched it at the lake, it would not start. Previously it has always been a quick starting motor and on my first try this season, it fired up quickly after storage. It's a 1994 Force 50 hp H050312PX. Lots of great info on this forum and this is what I've done/checked so far. Compression test is 130 psi on both cylinders. While cranking, I can see blue spark on both plugs when grounding to the cylinder head. I took the carb off and it looks nice and clean. The gas is fresh and mixed 50:1 and the bulb pumps and then gets hard. Battery is in it's second year and it cranks the motor well, I also replaced the fuel pump membrane last year. The fact that when it does start, it runs well has me thinking that the carb and fuel pump is working well. As a regular reader of this forum, I have compression, spark when I checked and the fuel system is working okay when it does run. The enricher clicks when I push the key in. I haven't tested the enricher, but it is on my to do list for tomorrow. I was thinking the enricher was the problem, but it did eventually start for me today and I ran it (in the bucket) until it was warm. When I tried to re-start warm without the enricher it wouldn't go. Any suggestions? I love this boat but it is frustrating me this season and any suggestions would be appreciated.
