pitlife4me
- Joined
- Sep 2, 2007
- 10
I'm good with auto's but just baught my first boat (17' 1990 Capri bay runner) and I'm having starting issues. When I tried to start it the motor turns over slow. I checked batt. and it was low so I charged it until I got 12v at motor and still turned over slow. I checked connections and all seem to be very clean so I baught new batt and still turns over slow. I checked on buying a new starter but that is very costly it seems and not to mention that they seem to be rare being that they dont make them anymore. (While I'm thinking about it I wasnt sure what starter to buy because all they had was a Merc. starter that they said fit 35hp-55hp.) I passed the sylinoid (not spelled right) and still turns over slow. I took the starter out cleaned brushes and put it back together and still turns over slow. I read that maybe it was to long of a run for the cables even though that the boat ran fine before so I hooked my truck straight to the starter and still turns over slow. I just ordered a starter for it and its on the way but would you think this is the problem? I know with motor bikes with 2 stroke they have decompresion switches to crank easier and thought maybe boat motors are the same. I thought about this because I did how ever pull out the #1 plug and the motor turned over fine and even started up. I put the plug in and can turn the motor over by hand pretty easily and this is what makes me believe that the starter is just weak. Has anyone else had this problem? I've seen other threads about this but no follow up on what the final step was. If the new starter doesnt work I have no choice I guess but to take it to someone else unless I'm missing something here. Please help me if you can.
