goblerblaster
- Joined
- Dec 26, 2011
- 180
I have replaced fuel lines, fuel filter, gas tank connector, gas line to motor connector, fuel pump, run a can of Seafoam thru it, a half can of B12 thru it, a dose of Merc Fuel system cleaner thru it, and it still surges. It will idle all day long. It runs pretty good at WOT. Between 2500 and 3500 rpm it starts surging It will go from 2500 to 4500 without touching the throttle. Then it will go back to 2000 or 2500 rpm. I can/t find any loose fuel lines or vacuum lines. Plugs look good. Seems like it is getting air in the lines, but I am at the end of my skill set.
Any suggestions? Gas is brand new. Any suggestions appreciated.
