50 HP Mercury Part Number Help
mutiny
I have a 50 Hp Mercury where I am trying to order O-rings for the intake plates. For some reason, I can find the part numbers for all of the O-rings except for #12. They skip over it in the list of parts. Im lost. Is there anyone who can give me a hand locating the part numbers for #12 on the schematic? Any help would be great. Thanks. I don't have access to Mercury's parts catalog directly so this is the reason I have hit a road block I suppose.
Serial Number is : 0T232863
50ELPT
mutiny
50ELPT
Thanks a ton Ga_Boater! I will order 12 just to be safe. Maybe the other 4 are located between the block, and the intake elbow? Either way I really appreciate the reply and info!!
GA_Boater
If you use the edited link I added in post #2 to the parts catalog, it shows #12 on the drawing and list.
GA_Boater
Found the missing 4 O-rings. Item #3 is the same part number. :noidea: why Merc lists them like that.
mutiny
Thanks for the resource! It appears that O-ring #3 and #12 calls for the same part numbers. Maybe this is the missing 4 O-rings. The only O-rings that call for a different part number seems to be #13. This is different info than what I got on marineengine. I will definitely go with the Mercury parts suggestions! Once again, I appreciate your assistance. EPC saved!
