i have a 50 hp rude mod #e50belcd..yesterday i used some seafoam to decarb the motor and wow what a lot of build up this motor had..there was a pile of gray like gell sitting under my prop after two go rounds with the old seafoam..that stuff realy works!before i used it i could not get my motot to idel less then 1500 but now it will idel as low as 450. but what im needing help with is resetting the timing. i have a manual but it says to use a timing gun and test tank. i was wondering if there is any way around this.?<br />thank you for reading<br />ben .c
